timelinex
Oct 02, 2023Explorer
dedmiston wrote:
Hey timelinex - I'm not sure that it works that way, but let me repeat it back to make sure I understand...
First of all, when you say HVAC I assume you mean air conditioning and not heat since the heater runs off 12v and doesn't need the gen.
You didn't say what you're doing for AC power to run the air conditioning, but I assume you're using an inverter (since the A/C won't run off your batteries) and not shore power (since you wouldn't need the gen if you have shore power).
If that's the case, then I don't know of an auto-start that's connected to the thermostat to start the gen X number of minutes before kicking on the air. The only auto-start function that I know of is triggered by the charge state of the batteries and comes on when your batteries get weak enough to require recharging.
Are you trying to run your air off of your batteries via an inverter? I don't think that would work anyway. Even if your inverter is wired to run your A/C units (which seems unlikely), the load would drain your batteries pretty quickly, to the point that you'd be better off running the gen the whole time anyway.
Or did I misunderstand your question completely? :B
The more I think about it, we only have two use cases with our A/C (and dogs):
1. We're heading out for the day and it's hot. If so, the A/C runs all day because it's hot all day, so we either need shore power or we need to run the gen all day.
2. It's the evening and it's hot enough to need the A/C running. In that case, the A/C stops and starts by the thermostat because it's not as hot as the daytime when it needs to run all day. In that case, we're home and we can switch the gen on and off.
OK, so I ran many variations of tests, but here is the exact test and setup that I believe tested it the way it's supposed to run.
I am boondocking, so no shore power. The generator is OFF. I did not have an inverter, so that is not in the picture.
I turn on the AC to cool and a temperature that is 1 degree hotter than the current temperature. So if my thermostat says its 80, I turn the AC onto 81. So the AC is "ON" according to the panel, but not running. (It wouldn't run anyways since no 120v). Then it turns 81/82 and I see my OneControl now says the AC is cooling. In other words, at some point a threshold is hit and it recognizes that it needs to "turn on" the AC. It "turns on" the AC, but it doesn't actually turn on since there is no 120v. Which is the point I would expect the generator to start.
Is that an incorrect understanding of how it should work?
Some of the other factors I tried is just setting it to a cooler temperature in the first place so it triggers it while I am still in the app. I also tried all 3 AC's separately incase only one is hooked up. The only thing I didn't try is setting the mode to heat & cool, versus just cool.
