gunny357
Jul 12, 2014Explorer
Do this the right way. Apparently changing parts (the thermostat) is not getting the desire results.
Use an amp meter and see what the actual load is. If below the rated capacity of the breaker (more than likely) then change the breaker. The can and do get weak and fail when they afe.
If amp load is above the rated capacity of the breaker, look for a failing compressor in you air conditioner. Air filters clean? Evaporator and condenser coils clean? Fan() working?
Having RV issues? Connect with others who have been in your shoes.24,411 PostsLatest Activity: Sep 06, 2026
