Gjac
Dec 10, 2015Explorer III
I would back your tow car next to the genset and jumper directly from your car to the starter and ground. If it starts you know it is either your battery or the connections. What is the resting voltage of your batteries? You can also use your button on the dash to combine the chassis and your house batteries together to see if that will turn your eng over. Again if it does you know your problem is either the batteries or connections.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
