MNtundraRet
Dec 10, 2015Navigator
You failed to state if you have a motor-home, or a trailer.
if you have a MH, then start the engine first which will allow alternator to charge the house-batteries. This also supplies around 14.5 volts to the 12v, dc, circuit allowing much for voltage than batteries alone (12.8 volts or less).
When checking connections you need to check all grounds near batteries, solenoids, and the generator.
The clicking sound usually means not enough current to run the starter. Depending on age the generator may have a dead spot or corroded, loose, connections internally. The control board may be bad, or bad connections.
Having RV issues? Connect with others who have been in your shoes.24,403 PostsLatest Activity: Aug 02, 2026
