TEXAS
Dec 13, 2015Explorer
Take the control cover off. Go to the start solenoid. Check with a test light. One large terminal will have battery voltage. The other will have none. With your light on the dead side. Try and start it. If you have no voltage the solenoid is bad. If you do have voltage the starter has a problem.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 23, 2026
