patperry2766's avatar
patperry2766
Explorer II
Oct 29, 2013
Generator DB ratings
When comparing generators:
#1 Are the posted db ratings at WOT, or at idle in eco mode?
#2 Is there a uniform db rating standard that all manufacturers adhere to, or is each manufacturer open to representing their #'s in a manner which is hard compare to others? Basically, is 60 db the same for Honda, Yamaha, Champion, etc?
  • Most manufacturers are trying to advance an industry standard of dB(A) at 7 meters (23 feet) with measurements for zero load, 1/4 load, 1/2 load or full load.
    The European Economic Community has a product standards for generators which allow for a maximum sound level of 71 dBA at 50 feet for low rated electrical output and 73 dBA at 50 feet for high rated electrical output.
    The National Park Service prohibits devices and equipment which exhibit noise greater than 60 dBA at 50 feet.
    Cummins/Onan uses a dBA at 10 feet rating.
    Here is an interesting study by an RVer on generator noise: http://www.klenger.net/RVing/Electrical_Generator_Noise/index.html
  • Most will give a DB rating and at what foot, usually in the 20-25 foot range, but no more info than that.
  • Bobbo's avatar
    Bobbo
    Explorer III
    Question #1, I don't know.
    Question #2, you have to read the details. They don't all test at the same distance from the generator. If you test at double the distance, it artificially reduces the dB rating.
Having RV issues? Connect with others who have been in your shoes.24,314 PostsLatest Activity: Sep 08, 2025
