I have an Onan 5500 generator (model 5.5HGJAB-6755D) that cranks but won't start and need some troubleshooting help. I have done the following: Replaced the carburetor and verified it's getting ...
There could be the chance the Low Crank warning is still right. Are all the battery cable connections clean and tight? Is this genset in a coach? If so, try starting the genny with your road engine running. If it's in a trailer you could still try to assist those batteries with a start pack or jumper cables from your truck. I'd just hate to see you tear into the genset when cranking voltage wasn't quite up to snuff.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
