mjbarr99
Feb 27, 2014Explorer
Generator Help
I have an Onan 5500 generator (model 5.5HGJAB-6755D) that cranks but won't start and need some troubleshooting help. I have done the following: Replaced the carburetor and verified it's getting ...
j-d wrote:
There could be the chance the Low Crank warning is still right. Are all the battery cable connections clean and tight? Is this genset in a coach? If so, try starting the genny with your road engine running. If it's in a trailer you could still try to assist those batteries with a start pack or jumper cables from your truck.
I'd just hate to see you tear into the genset when cranking voltage wasn't quite up to snuff.
