Tal_IL's avatar
Tal_IL
generator issue?
Spent the weekend in a giant mud hole, AKA Lot 1A at Indianapolis Motor Speedway where we had no electric. We ran the generator most of the time. It was the first time we've run it more than a couple hours at a time and after it had been running overight we had an odd situation.
Tried to use the microwave to re-heat some coffee Sat morning - generator had been running overnight and the AC had cycled off normally. The microwave would run for about 5 seconds hen shut down and power off. In a few seconds it would re-set and could be restarted, but did the same thing. I checked the EMS and it showed 131 volts and a "high voltage" error code. All other electrical equipment was working fine. When the AC cycled on the voltage dropped to 124, but the EMS showed a "high cycle" error. When the AC was running the microwave worked fine.
I'm guessing there is some calibration needed on the generator. Has anyone dealt with this before?
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
