marty1300's avatar
marty1300
Generator issue
UPDATE
found the issue I believe, there is a compartment next to the generator and inside there is a junction box. Stranded wires from the generator are wire nutted to solid wire going to outlet in the rearmost compartment where the shore cable is. These wires were burnt, looks like the neutral . Will need to get them reconnected when I get home
Class c with onan 4K generator. Last night had air conditioner on and using microwave. We have done this before no issues. For some reason microwave stopped, then Air conditioner. Break on generator is not tripped, but I was not getting sufficient power. We use a manual transfer(move cord from shore to plug for gen). When I plug in my small portable generator to the shore cord I get power back to rv. Seems the issue is with generator wiring.? Any advice on what to look at. I did measure 120 volts on the black and ground on the back of the outlet when generator was on. Could not get a reading when on the white wire.
Marty
Having RV issues? Connect with others who have been in your shoes.24,312 PostsLatest Activity: Sep 06, 2025
