jrnymn7
Nov 12, 2014Explorer
littlemo wrote:
We have our MH at our Deer Camp right now. Have had a few cloudy days so solar panels not much help. DH says the Generator not charging batteries but when he starts the Truck THAT battery charges it?
I believe you mean the truck's alternator charges the battery just fine.
As others have pointed out, (unless the gen is set up to charge the batteries directly), the gen supplies 120v AC power to a converter/charger, which in turn, supplies approx. 12-15v DC power to the batteries and rig.
Make sure the converter's 120 ac plug is indeed plugged in. Also check if the converter is properly wired to the batteries. With generator running, check its 120v ac output. If that's fine, check the converter's output. It should be either in boost mode or normal mode... boost being probably somewhere in the 14.0-14.6 range, normal being in the 13.6v range.
Post the make and model of the converter here, so folks here can better help you.
Also, check any fuses or breakers in the circuit between generator, converter, and batts.
And x2 on the combo inverter/charger possibility.
My guess is the solar didn't keep up with the demand on the batteries, so they eventually went dead. You will need to learn how to properly monitor (and maintain) your batteries, so this doesn't happen again and again. :)
With them being new batteries, it would be beneficial to get them properly conditioned before putting them into full time service. Please see the thread "first top charge" to get advice on preparing your new batteries for reliable full time service.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
