YC_1
Nov 12, 2014Nomad
Yep, need to know mh model number and year. Some older units charged at a very low rate. I had one that charged at 3 amps. That was a pain.
2012 Forest River Sunseeker 2450 is what you have after digging through your profile.
So a 2012 should have a good charger. You need to find the manual for your converter panel and check fuses per the manual.
Oh, just another thought. Some RV's need to have the shoreline cord plugged into an outlet in the compartment the cord is in. Never mind, brochure says it has an automatic transfer switch.
Check your AC outlets to see if they are working. If not check any breakers on your generator.
If your AC outlets are hot then back to the converter to see if the charge line fuses are popped.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
