sharp3
Jun 18, 2013Explorer
Wayne Dohnal wrote:
Does your regulator have a primer button? That should get enough natural gas into it for starting.
Yes the primer button pumps the NG directly into the carb and i can hear it but still doesn't start. After the engine is warm (by starting and running it on gasoline for a 2-3 minutes), i prime it for a moment than crank and it starts on NG.
bushman512003 wrote:
Do You use Propane ?or natural gas there is a big big difference if propane check the vent hose on the propane regulater for a blockage as in a mud dobber or spider nest no vent no start ...Bushman
I use Natural Gas and the regulator is a brand new one with no dust and blockage.
Having RV issues? Connect with others who have been in your shoes.24,378 PostsLatest Activity: Apr 12, 2026
