Gjac wrote:
NinerBikes wrote:
Moisture, condensation, in the oil, forms acids, forms rust or acts in a corrosive manner. Hence the R&R of motor oil.
I can see moisture building up especially over the winter in the main eng when stored. If the genset is exercised once a mo for an hr or in the OP's case almost double that won't this drive off the moisture and prevent rusting?
Yes...exercising the genset helps prevent rust/condensation buildup. Also, regular oil & filter change, at least yearly is wise and cheap insurance for a healthy genset.
