Jdaniel343's avatar
Jdaniel343
Generator output voltage
I have a Kipor KGE 3000TI I bought used.
Generator runs my 13000 btu ac using 30amp plug. Also the 120v outlets will power equipment like a angle grinder just fine.
When I use multimeter to check voltage output at the outlets I'm only seeing 60 volts or so. Why is this?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    There are two possible answers... There are two types of multi-meters.
    Some are "Peak reading" and show you a reading that is as I recall about .707 times the actual voltage Others are True RMS.
    Now I'd hope the Inverter generator is True Sine wave or Pure Sine wave out put (There is really only one way to be sure and I do have the test devices)
    But if it is not a peak readin meter will read low. but equipment will work (Non electronic that is)...
    But I suspect the meter as well. Try a different meter.. In this case cheaper(Like the 5dollar harbor freight job)might just be better.
Having RV issues? Connect with others who have been in your shoes.24,354 PostsLatest Activity: Jan 24, 2026
