onemountainman's avatar
Apr 25, 2016
Generator Polarity
Hello, I'm new to the forum, so please forgive me if I mess it up.
I bought a 2015 Jayco 23RLSW. Also, for dry camping I purchased a Briggs & Stratton 5000w / 6250w peak generator. When I hook up the generator everything works great.
My sister said, wow a lot of power but that thing is Loud As Hell. So, I thought for light duty, I would also get something smaller to run the tv at night. So, I bought the Powerhouse 2100 PRi. Starts fine, although I can't get the remote start to work yet, still working on that. But when I connect the trailer, the polarity is reversed.
Not really sure, what I need to do to reverse the polarity.
Thanks!
  • Just for TV you might be able to get by on battery alone. For QUIET generator, and Honda EU1000 or 2000 is as quiet as it can get.
    Polarity ?
  • what says reverse polarity
    one of those little tester plugs ?
    i got one , it says open ground, every time i run the portable generator
    those things, are not for testing generator power
    which does not have an earth ground bonded to the neutral wire
    AC does not have a real polarity, just an assumed polarity to make sure bonded neutral is always in the same slot, always on the white wire,
    if everything works, just run it
    if your power management system panel inside the RV says reverse
    then use the bonding plug described above
  • corvettekent wrote:
    Why not just use an inverter to watch TV with?
    X2.
    Nobody likes being around someone who has to run a generator (and not a particularly quiet one) to watch tv.
    Wish you'd asked us first. That's not suitable for camping.
  • Inverter genset do not have a tie between the neutral and ground internally. You need to assemble a dummy plug with a jumper between the neutral (white screw) and the ground (Green screw). Use a good quality 15 amp male cord body with a jumper of copper wire somewhere around 16 or 14 gauge.
  • How do you know the polarity is reversed? Please give more information maybe some photos
Having RV issues? Connect with others who have been in your shoes.24,308 PostsLatest Activity: Sep 02, 2025
