cavie
May 23, 2019Explorer
BFL13 wrote:
You have lost 120v input to the converter, so there is no output to run 12v items from the converter, even with no battery.
Check the 120v breaker for the converter, and also if the converter is plugged into a wall receptacle, whether that is on a GFCI circuit that might have its GFCI popped.
Converter would be hard wired into shore power. It converts 120 volts to 12 volts and charges the battery. It has nothing to do with the GFI circuit.
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
