JandKSunshine's avatar
Aug 25, 2017
Generator putting out 18 Hz?
Hello again! Man, I've been running down one problem after the next on this old generator we have. I finally got it running after a no-start and then a broken fuel line. Still need to fix the muffler. But now this:
I got the generator running and hooked up, with power going to the RV. It wouldn't run our AC, though, so I hooked up our surge protector that reads the voltage and frequency and all that.
It says 102 V, 18 Hz.
What could that possibly be? Maybe one side of the AC is dead? I checked the connections at the box, they look good. Could it be the brushes? I'm starting to wonder if I should just start budgeting for a new generator. lol
Again, your help is really appreciated. Thanks!
  • The brushes on the rotor slip rings control current and voltage to the rotor which controls output voltage
    Nothing to do with Hz, that is strictly rotation speed which is controlled by the governor
    Only one winding in the rotor
    The stator winding are the poles
    One runs at 3600 rpm
    Two runs st 1800 rpm
    Three runs at 1200 rpm
    I have never seen a gas RV Onan three pole 1200, rpm model,
    I'm not going to claim they were never made, just i have never seen one
    To get 18 Hz you need a dead winding in a two pole running at about half speed, just above half speed
  • Yes but time it with another clock
    Do not use a digital on the generator, need a motorized clock
    Ten minutes then shut off generator and check the clock plugged into generator
  • In generator lingo ???-turn (two pole) 3,600 RPM
    18-turn (four poles) 1,800 RPM
    12-turn (six poles) 1,200 RPM
    Below a 55 Hz (cornering frequency) many regs wll go intermittent meaning their signal to the field isn't continuous.
    Even a cheap multimeter will have Hz. And I sure would trust it more than a "meter" on some line monitor device.
    When an suspicious value is offered I immediately suspect the measuring device until its measurement can be corroborated with another device.
    34 years ago when I assembled a Kubota to a Kato generator, I had a miserable time finding a 12 turn power head that was a 12-turn. And to think anything under 12.5 Kw was available in a 12-turn would have been a pipe dream.
  • On AMAZON
    Alloet
    Alloet DT-9208A Digital Multimeter LCD Multi-tester Volt Amp Ohm Hz AC/DC Temperature Hertz Tester Detector
    Be the first to review this item
    Price: $17.99
    Sale: $12.20 & FREE Shipping
    You Save: $5.79 (32%)
    IS
    Icstation Mini AC 80-300V 45Hz-65Hz Digital Voltmeter Frequency Meter LCD Display Blue Backlight 2 Wire Black
    5.0 out of 5 stars 3 customer reviews
    Price: $14.99
    Sale: $7.99 + $2.49 shipping
  • JANDKSUNSHINE Recheck I think you will find the Genny to be a BGE not gbe.
    And with that in mind, An Onan Emerald Plus BGE is an 1800 RPM generator. 2 cylinder boxer engine, oil pump and oil filter. So disregard all that info about 3600 RPM generators.
    If you don't properly identify the item that failed, all you get is guesses.
    Richard
    Richard
    Give the guy the benefit of he is new to RV World. Transposing 2 letters
    He could be dyslexic we don't know
  • this goes back to the govenor and how fast is it running
    is really running only 900 or so RPM ?
    or is there an open winding ? in the stator
    or just a bad voltage regulator, messing with the sinewave giving a bad reading on the surge guard
    plug in a fan or a clock and see what is really going on
    a typical box fan is going to run way slow if its really 18hz
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 17, 2025
