swp5767
Aug 06, 2013Explorer
copeland343 wrote:
If meter is correct you will need to slow rpms down a little. Using the speed adjustment screw maybe a 1/16 of a turn.
There is only one screw to adjust, but when I back it out some, it does not make contact anymore nor does the RPM lower anymore.. I can physically push it till the screw makes contact again and the RPM is lower, but as soon as I let go, it goes back into place.
There must be more to that setting.. I don't see any kind of voltage regulator on this unit.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 24, 2026
