Bobbo
Oct 16, 2021Explorer III
A cheap 3 light tester will tell you if the generator is putting out power, no knowledge needed. Just plug it in. If you have a bonded neutral, then two lights should light up. If you have a floating neutral, then one, and only one, light should light up. Both of those are normal results and show the generator is putting out power. (A floating neutral is reported by this device as an "OPEN GROUND.")
