Bobbo
Oct 17, 2021Explorer III
Janss wrote:
Bobbo...I wouldn't know where to plug that tester in. My generator and shore power are hardwired to the automatic transfer box.
Sorry about that. I thought it was a portable generator. If you can get to the wires going from the generator to the ATS, you can use a Non Contact Voltage Tester. Touching the tip to the insulation over the hot wire makes it light up/beep. Touching the tip to the neutral or ground wire does not. If you can get to the wire, touch the tip to all sides of the wire.
