gbopp
Jul 24, 2016Explorer
palmerjp wrote:
I am not tripping any breakers
Is there any way to clean carb without removing carb and or generator
You don't need to remove the carburetor or generator. Tap into the fuel line going into the carb, feed the gas/Seafoam mixture into the running generator. Shut off and leave it sit for several hours.
The Seafoam will dissolve the gunk in the carb.
Start the generator, see if it solved the problem. Repeat if necessary.
Try it before tearing the carb apart or replacing it.
Also, replace your carburetor fuel filter.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
