95jersey wrote:
time2roll wrote:
Exactly what generator do you have? Does it include a 30 amp 120v RV connector?
The 4000/3200 HF generators I see split power between a 120/240 twistlock outlet and some 5-20 outlets. Either way you might be only getting half the power due to the split nature of the design.
I have this generator.
https://www.harborfreight.com/engines-generators/gas-engine-generators/4000-max-starting3200-running-watts-65-hp-212cc-generator-epa-iii-with-gfci-outlet-protection-63080.html
Yes you are basically running on just one side of the generator getting 1/2 the listed power.
You want something like this with a NEMA 30-TT connector
https://www.championpowerequipment.com/product/100233-3400-watt-inverter/
