MrWizard
Mar 20, 2016Moderator
12v main circuit breaker ?
you have 12v power, until you start the generator ?
then this 'breaker' trips and everything goes black ?
are you on shore power ? how are the batteries charged
yes .. there is a load, the converter will come on as soon as the timer on the ATS kicks in, also possible is any switch that might accidentally be on, like water heater or fridge
a bad converter or two many items in the on position, will cause a small generator to stall, 2800 is NOT a large generator
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
