DownTheAvenue
Mar 21, 2016Explorer
wa8yxm wrote:
I can tell you why the generator stalls. but not why the breaker is breakering.
The generator uses 12 volt BATTERY/CONVERTER power for the fuel pump and for ignition control.. So if it looses the 12 volt feed due to the main breaker tripping, It's the same as pressing the OFF button. or turning off the ignition on your car.. It does not "Stall" it is "Shut Off".
But I have no idea why the breaker is breakering.. Possible converter issue. that is the only thing I can think of, is a converter issue.
This helps to explain why the generator quits. I assumed it stalled. It is in a class B van AKA "motorhome".
Thanks!
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 01, 2026
