maillemaker's avatar
maillemaker
Generator takes a long time to start now.
Back on the Solar Eclipse day, we discovered that our RV generator would not start due to a cracked fuel line. I had my local auto mechanic fix it.
The generator now runs, but it takes a very long time to get it to start. Like about 5 minutes of trying.
I wonder if perhaps there was a check valve in the line that they possibly removed while fixing the leak, and now the electric pump at the genset has to run a while to suck fuel back up the fuel line.
Once the generator is running it runs fine.
RV is a 1990 Winnebago Warrior. Generator is a Onan 4000 4BGEFA26101A
Steve
  • When he replaced the fuel line he should have dropped the tank and replaced the whole line. It sounds like you still have a leak . There is a shutoff valve on the bottom of the carb that acts as a check valve.
  • I had that problem with my genset. It got progressively worse until it wouldn't start at all. Turned out that the fuel pump needed to be replaced.
  • You ARE doing the "prime" thing before starting.....right ??
    If so, I'd do two things:
    Have the choke checked.....and/or watch it as you try to start with the on-gen switch.
    Give it a healthy dose of a good carb cleaner. Berrymans or Gumout. Might take a lot if you have a shared tank and it's full.
