tpi
May 11, 2015Explorer
MEXICOWANDERER wrote:
Turn off EVERY LAST A.C. load in the rig.
Cross your fingers and toes
Start the unit's fan first
Then continue on to start the compressor
It may or may not start without killing the generator. A hard start air conditioner kit may or may not work to help the AC to start.
Once the AC starts it has to keep running. Solid.
If it shuts off a five minute wait to re-start will be mandatory. High head amperage requirement will toss a knockout punch to the generator. Stall.
Was this unspecific enough? Not trying to be cute, this is the reality of an answer.
If you already have the Honda 2000 and want to try it, the above quote is the way to go. Specifically when he mentions turning off all AC load, there are elephants in the room-the fridge (needs to be on gas), water heater off 120V, and the power converter shut off. Plus anything plugged into outlets. It may or may not work.
If you don't own a generator, count me in with nearly everyone-get a 3000 watt or greater generator capacity for use of air conditioner.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
