elderberries
May 11, 2015Explorer
All right, I finally found the specs on the a/c unit. 13,500 BTU and 115V?
http://www.americanrvcompany.com/Dometic-B57915-Brisk-II-RV-Air-Conditioner-13500-BTU-White
So looking at Amazon, I see two beefy generators, both 1/3 of the price of the honda. I'm sure they're not nearly as quiet, but I'll only end up using them 3-4 times a year most likely, so dropping another $1200 doesn't make much sense.
The Duromax 4400E:
http://smile.amazon.com/dp/B001BMDFPS/ref=psdc_348967011_t1_B004054GN8
or the Champion 4000:
http://smile.amazon.com/Champion-Equipment-46533-Generator-Compliant/dp/B004054GN8/ref=zg_bs_5006643011_18
Both around the same price, and if I'm reading things correctly, both would allow me to just plug the RV power cable straight into it, with no adaptor? Please let me know if anyone can think of a reason that wouldn't work!
We're running a small music stage with lighting next to the trailer, so I can always use the Honda generator for that, and save the beefy one to run the RV AC at nights (texas trip.)
Thanks again to those of you who took the time to impart your wisdom. :)
The Duromax 4400E:
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 17, 2026
