2oldman
Mar 22, 2014Explorer II
bowler1 wrote:Yes, two in parallel should work, even on Eco mode. There's quite a voltage drop when starting my air in Eco, so non-Eco might work for you, but then they're running full bore and louder.
a Honda EU2000i. .. I also could eventually buy a second and run them in parallel. as I assume that running the two Hondas results in doubling the watts and amps,..running in parallel likely be quieter .. I assume that the two Honda setup would run at a lower RPM and be quieter.
Yes, the amps and watts are doubled. Two are not loud at all, but definitely louder than running the TV.
