otrfun
Mar 23, 2014Explorer II
ol Bombero-JC wrote:For some, I think installing a hard-start cap is a reasonable thing to try in order to get a Yamaha EF2400iSHC to work with their 13,500 BTU a/c. However, I think it's important to keep in mind this generator is operating on the outer fringe of its capability with any 13.5 a/c. If you have any plans to power a different a/c unit, whether it be your friends, a new TT, in 110 degree heat, or at 4,000 ft., you're always gonna run the risk it may not work. Just something to consider before committing to the EF2400iSHC for the long haul.Wayne Dohnal wrote:With no other loads, (and, of course individually) -
I'm really surprised the 2400 doesn't run the air conditioner because my eu2000i ran one reliably. Make sure the fridge is on 'gas only', that's easy to miss, and of course the electric water heater element isn't on. You'd maybe have to kill the converter, too, but I'd think the 2400 would handle it and the air conditioner most of the time. Some of the air conditioners ship without a hard start capacitor. Saves a couple of dollars. That could be the issue. I'm assuming a reasonably low altitude. All bets are off is you're higher than a couple thousand feet.
My Yam 2400is starts & runs the factory supplied 15K btu A/C on my 5th just fine.
The trailer has a second factory *optional* 13.5 btu A/C for the bedroom. The Yam will struggle to get it going - then OK.
Suspect the optional (13.5) A/C doesn't have a hard start capacitor.
(Never bothered to check)
Caveat: Haven't tried any high altitude operation.
