bowler1's avatar
bowler1
Generator to Start My A/C--Yamaha 2400, Honda 2000?????
Hi,
I just bought a new rig with a 13,500 air conditioner. I currently have a Yamaha 2400iHC. The generator worked with my older set up (also a 13.5 air conditioner) but not with this one. It just can't seem to start it.
I have done some research online. I am going to try shutting off the circuit to the RV's inverter/battery charger and see if that helps. I also read something about installing a Supco capacitor. I may try that too; although, I am not sure if there are any potential drawbacks in terms of it potentially damaging your A/C unit. Not sure if anyone can comment.
Here is my next option---I found a great deal on a Honda EU2000i. If I can't run the a/c with the Yamaha the Honda is certainly more portable. I also could eventually buy a second and run them in parallel.
Would this setup be more likely to run my A/C if the 2400 does not work? I assume the answer is yes, as I assume that running the two Hondas results in doubling the watts and amps, but I am not sure if that is true.
Also, would the two Honda setup running in parallel likely be quieter when running the A/C than the Yamaha, assuming that I can get the Yamaha to do it? I assume that the two Honda setup would run at a lower RPM and be quieter.
Any thoughts?
thanks
matt
  • the hard start capacitor might solve your problems. but why not get a second Yamaha instead of buying two Hondas? assuming you can parallel the yamaha. or buy a yamaha 2800 or so that you can take when you need the aC and the 2400 for other times?
    bumpy
