SCClockDr
Aug 12, 2013Explorer
becworth wrote:
It keeps shutting off while driving and there is plenty of gas. Any suggestions? Also, it was just serviced. (oil, filters, etc)
While the unit was just serviced the oil level may still be a tad low. That does not suggest poor service, just a bit less than optimum for running while underway. As the unit gets subjected to normal road forces the low oil sensor may go dry intermittently. Just a small bit more oil should cure it. Too much and the air filter could get soaked, the over/under band is a bit narrow.
Go slow adding a few ounces @ a time. Make a note of the oil level once you get it sorted.
