DrewE
Nov 08, 2016Explorer III
A three volt fluctuation is well within the usual tolerance or specs for 120V utility power. Absent any other problems, I wouldn't worry about it. That should not be causing your 12V lights to noticeably flicker. (119V to 122V also sounds reasonable for a 120V nominal output, though I don't know what the voltage vs. load specs are for this particular generator.)
Lights flickering may be due to a poor or slightly undersized connection in the 12V system, coupled with varying other 12V loads. Making sure all the connections (ground and power) are clean and tight in the 12V system would be a reasonable first step to take.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 19, 2026
