fourthclassC
Sep 07, 2016Explorer
Based on my limited know how of these I suggest it is related to the electrical out put or lack of it. The symptoms are like the known fuel pump problem of not working when hot but since you have a new one it can't be that. I believe the engine will not run unless it is putting out he correct electrical power. Can you check the brushes and slip rings on the generator side without dropping the unit.?
Having RV issues? Connect with others who have been in your shoes.24,401 PostsLatest Activity: Jul 23, 2026
