dclarke618's avatar
dclarke618
Generator won't turnover from inside motorhome
I have a 1998 Winnebago with a 4000 watt Onan generator.
Generator won't turnover from inside motor home. Starts fine using switch on the generator. Once started, the inside off switch works fine. Anyone have any advice about where to start?
Thanks,
Dave
  • Where is the remote control fuse etc on the generator? I saw 1 fuse and 1 breaker. Both looked fine,
  • Loose connector going to remote panel
    Blown fuse on remote control system in genset
  • It worked fine last week, so hopefully is is a loose connection. I'll give it a try. Thanks all!
  • I'd start with an electrical schematic and a VOM. Might be a terminal pulled off of the switch. Could be a relay, you are just going to have to trace out the system and find where you lose power.
  • When mine did that I pulled the connection wires on generator cleaned them and reinstalled problem solved.
Having RV issues? Connect with others who have been in your shoes.24,313 PostsLatest Activity: Sep 07, 2025
