- dclarke618ExplorerWhere is the remote control fuse etc on the generator? I saw 1 fuse and 1 breaker. Both looked fine,
- Loose connector going to remote panel
Blown fuse on remote control system in genset - dclarke618ExplorerIt worked fine last week, so hopefully is is a loose connection. I'll give it a try. Thanks all!
- BTPO1ExplorerI'd start with an electrical schematic and a VOM. Might be a terminal pulled off of the switch. Could be a relay, you are just going to have to trace out the system and find where you lose power.
- John_WayneExplorer IIWhen mine did that I pulled the connection wires on generator cleaned them and reinstalled problem solved.
Having RV issues? Connect with others who have been in your shoes.24,333 PostsLatest Activity: Nov 07, 2025
