enblethen
Mar 31, 2018Nomad
3100 peak, check the specs it is probable close to 2800 continuous. Oops I see that later in post.
AC unit is rated for run not for start up. Could hit 15 amps start up.
Converter output will vary bases on the condition of the batteries.
No, you should not shut off converter. You can by shutting off 120 volt circuit breaker feeding it.
You should have somewhere around a 3500 genset.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
