Lantley
Apr 01, 2018Nomad
Don't be too quick to pass on the propane model. Propane is much easier to transport than gasoline. I would also suggest consider your usage.
If you plan to run genset occasionally hours at a time propane is fine.
If you plan to run genset regularly days at a time go with gas.
If genset is use frequently gas is fine however if it will be idle and stored for long periods propane wins
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
