ktmrfs
Aug 03, 2014Explorer III
instead of bypassing the EMS due to a unbonded ground/neutral, there sn alternative. Make yourself a "bonding" plug. go to a hardware store and buy a 3 prong replacement plug for a power cord. Take a piece of #14 stranded wire and connect the ground pin to the neutral pin on the plug. Do NOT connect anything to the hot leg. put the cover back on the plug. plug this into one of the outlets on the honda. Now the EMS will work. Note, this does NOT work on the 2000 Companion, since it only has ONE plug. This is one of three solutions that you will get if you call about the EMS and this problem with most portable generators.
If you have the EMS unit without the remote display and bypass switch you WILL need to do this or something similar to be able to power the trailer.
