ktmrfs
Aug 03, 2014Explorer III
otrfun wrote:ktmrfs wrote:A bonding plug works fine with the EU2000i Companion, both, solo and/or paralleled (with or without EMS protection turned on). See the attached schematic. Note the NEMA L5-30 (30 amp) outlet on the Companion is simply paralleled with the NEMA 5-20 (15-20 amp) outlet. A bonding plug on either outlet of the Companion will work. FWIW, the 20 amp circuit breaker is the only thing that prevents 30 amps from entering the NEMA 5-20 outlet when the Companion is paralleled.
. . . Make yourself a "bonding" plug . . . Note, this does NOT work on the 2000 Companion, since it only has ONE plug . . .
you are correct, and thanks for clarifying. sorry my post was in error. I was going by memory (on vacation) and forgot that the companion has a std 20A plug AND the 30A. so yup, a bonding plug in the 20A solves the problem.
