time2roll
Aug 14, 2012Nomad
ZZSPIRAL1 wrote:
Okay, if I understand correctly:
2. If we assume the generator provides 7.5 amps of power into the converter, then simple math says the converter will provide 10 times that (75 amps) into the battery. This is because the generator provides 120 volts and the converter converts it to 12 volts.
Conversion has some losses. And due to power factor the generator will need more apparent power than is used. So use a factor of 5 or 6 instead of 10.
7.5a gen = 45 amps battery.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 19, 2026
