HiTech
May 28, 2013Explorer
smkettner wrote:MEXICOWANDERER wrote:
Hi, This is a question and not a statement...
Has anyone out there experimented with different chargers and converters and has come to a conclusion WHICH charger or converter loses LEAST amperage potential at 100 volts versus 120 volts? Read "potential" it is a percentage differential. That is to ask, WHICH brand and model of converter or charger is LEAST negatively affected by low voltage.
Thank You
This would be worthy of a new thread. Wish I had some answers but if I had to speculate IOTA would perform best with low voltage. Or Xantrex Truecharge has a fairly low input voltage rating and will tolerate high voltage also.
Reading specs on the VEC1093DBD, it says it compensates for low voltage. Not the same thing, but a possibility that it was at least designed with low voltage in mind.
Jim
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
