Wayne_Dohnal
May 28, 2013Explorer
MEXICOWANDERER wrote:I can answer that for 2 converters. The PD9160A needs a clean sine wave of 120 volts or more to produce its rated current in boost mode. On the other hand, the WFCO 8955 produces its rated current in boost mode no matter what kind of crappy power you feed it with, in terms of waveform or low voltage (within reason of course). Sorry for the general statement, I haven't tried every possible form of substandard power. With the WFCO refusing to go into boost mode in most installations, its robust power supply is unfortunately wasted most of the time.
Hi, This is a question and not a statement...
Has anyone out there experimented with different chargers and converters and has come to a conclusion WHICH charger or converter loses LEAST amperage potential at 100 volts versus 120 volts? Read "potential" it is a percentage differential. That is to ask, WHICH brand and model of converter or charger is LEAST negatively affected by low voltage.
Thank You
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
