enblethen
Aug 02, 2019Nomad
Are you disconnected from the shore power?
Remove shore power from pedestal. The transfer switch could be seeing power to hold it in shore powr and not allowing to go to genset.
Pedestal back to the sservice point is responsibility of the park. If it was the power utility problem, you would not be the only one effected.
Sounds like an open neutral in park system.
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
