Planning
Aug 03, 2019Explorer
Jim McGarvie wrote:In addition to the other suggestions, if you are using a Progressive Industries EMS, you might have an unbonded neutral on your generator and the EMS will not allow power into the coach in that situation.
Thanks for the reply. No, it is an Intellitec EMS. Interestingly, turns out the original problem with the pedestal (and two others) was an unbounded neutral. That has been fixed but we can't use the pedestal or the generator due to the damage incurred, probably to the EMS.
Jim
Replace your EMS with one that protects against open neutral, for example the Progressive EMS-HW50C
https://www.progressiveindustries.net/ems-hw50c
Having RV issues? Connect with others who have been in your shoes.24,387 PostsLatest Activity: May 20, 2026
