otrfun
Oct 26, 2014Explorer II
johndeerefarmer wrote:It would probably "work". However, under high load one may end up exceeding the maximum current rating of the parallel cable kit itself and/or some of the internal circuity of each generator to include the L5 30 amp plug on the Companion unit (delivers the total, combined output when paralleled).
. . . Second since I already own two Hondas, has anyone put three in parallel? This would give me 6000W surge and 5400W running which would be plenty. I would have to splice into the parallel cable to go over to the third unit but this wouldn't be a problem. I would also have to change the plumbing on my BERG tank which wouldn't be an issue either . . .
