Our RV forgot it was housetrained! do you think this is just a gasket that needs replacing? Maybe that oval thing with the screw each end. we assume we will have to replenish the oil. anything els...
See if the drain plug is tight. Can you see one in the picture. i suspect that oval plate IS the drain plug! i assume (hope?) there is a gasket behind it. thanks guys
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
