Gdetrailer
Feb 18, 2021Explorer III
KD4UPL wrote:
The point of running a generator under load every month, according to Onan anyway, is to produce heat in the windings and help dry out moisture.
That is a pretty much "CYA" statement.
The "windings" of all generators just like any good AC motor are DIPPED in a INSULATING AND MOISTURE PROOFING VARNISH..
The windings are then heat cured in an oven and then HiPot tested to ensure no electrical leakage or breakdown of the insulation before windings are installed.
As long as your gen is not sitting out in the yard in the rain and the windings are not directly flooded by water there is no "need" to "produce heat in the windings to dry out the moisture"..
Besides, the very second you shut it down the moisture held in the air around the gen WILL start redepositing back on and into the windings.. You simply cannot fight the fact that the air holds moisture right up to 100% humidity.
Having RV issues? Connect with others who have been in your shoes.24,386 PostsLatest Activity: Nov 08, 2021
