TEXAS
Aug 20, 2013Explorer
If you unplug the regulator. There will be no AC out put. Plug it back in. Get a volt meter and do some test. Make sure you have no output before you spend any money. Also look at the oil pan. If it has a wire going to it. Unplug it. That is the low oil level sensor. The early models had them. But they caused so many problems Onan got rid of them. Get the service manual it will have all the test you need.Easy to check things out.If you will post the full model and serial number. The guys on smokstak. Can send you a manual.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
