Handbasket
Aug 20, 2013Explorer
If you're still looking for tips on removing it from the MH, here's one, maybe... My 2800 is bigger (wider and taller) than the compartment door opening. I found that I had to remove the door and door frame. Peel the rubber trim out of the channel around the door frame to get to the screws. Still a PITA, but doable now.
(on edit) While it's out, and if you'll still have air circulation space around it, put some foil-faced rigid fiberglass insulation on the compartment walls, and make some big rubber washers for the mounting bolts (between gen pan and frame); use blue Loctite and longer bolts, tightened just snug. See the Onan installation manual for details on required clearances. Most MoHo builders cheap-out on generator installation, resulting in a noiser-than-necessary product.
Jim, "Why are there never any _guilty_ bystanders?"
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
